Hi there, is it possible to test "Lock Overrides" and return if it is on or off using Python? The same question for the "Enable all overrides" button.
Hello @danielsian,
thank you for reaching out to us. Yes, this is possible with c4d.IsCommandChecked(). You just need the id for the command you are interested in, the Script Log is a good way to figure them out. See the example at the end of the posting for details.
Cheers, Ferdinand
The example:
import c4d def main(): """ """ # When the "Lock Overrides" button is checked ... if c4d.IsCommandChecked(431000108): print ("Do something") if __name__=='__main__': main()
Thank you very much @ferdinand, that's exactly what I was looking for. Cheers
without any further activity before Wednesday, the 16.03.2022, we will consider this topic as solved and remove the "unsolved" state from this topic.
