Dear Developers,
I want to draw some Maxon ID icons into my treeview list. Very similar tor the missing texture list inside c4d
I dabled with these two functions but can't get the to work
get it to work prior to R25 would be a bonus
Thanks in advance.
# here i can't figure out what to put into mode= maxon.IMAGEINTERPOLATIONMODE geUserArea.DrawImageRef(1018641, wx=0, wy=0, ww=16, wh=16, opacity=0.5, mode= maxon.IMAGEINTERPOLATIONMODE) # how do i injest a maxon icon into the basebitmap ? geUserArea.DrawBitmap(c4d.basebitmap, wx=0, wy=0, ww=16, wh=16, x=0, y=0, w=16, h=16, mode=c4d.BMP_NORMAL)
just for context here my COL method from the treelist example:
if col == ID_INSCENE: #icon 13957 X #icon 1018640 OK Checkmark #icon 1018641 X Not ok red self.rootobj = getallrootnull_name() name = "" #name = self.drawicon() if str(obj) in self.rootobj: name = "found" #name = obj.getfilepath() geUserArea = drawinfo["frame"] w = geUserArea.DrawGetTextWidth(name) h = geUserArea.DrawGetFontHeight() xpos = drawinfo["xpos"] ypos = drawinfo["ypos"] + drawinfo["height"] #drawinfo["frame"].DrawText(name, xpos, ypos - int(h * 1.1) ) drawinfo["frame"].DrawImageRef(1018641, wx=0, wy=0, ww=16, wh=16, opacity=0.5, mode=0)
kind regards mogh
You should use the function DrawCell to draw your icon. That is probably what you are doing but it's not clear.
This thread should help you to understand how to do it.
You can retrieve any icon with the command c4d.gui.GetIcon(lIconID)
You can find the IDs of the icons on that page
Cheers, Manuel
Thanks, @m_magalhaes yes my code is inside the drawcell() method.
drawcell()
I didn' have any luck with c4d.gui.GetIcon(lIconID) but i got c4d.bitmaps.InitResourceBitmap(resource_id) working.
here are my 3 lines of code that got me an icon.
ICON_SIZE = drawinfo["height"] bmp = c4d.bitmaps.InitResourceBitmap(12098) geUserArea.DrawBitmap(bmp, drawinfo["xpos"], drawinfo["ypos"], ICON_SIZE, ICON_SIZE, 0, 0, bmp.GetBw(), bmp.GetBh(), c4d.BMP_ALLOWALPHA)
