Dear Developers,
I have a python script which saves the unsaved (untiteled) active document to a *_imported.c4d file which works fine, but Cinema still has the original "Untiteled" Filename active how can I activate the successfully saved file in Cinema 4D and discard the "untiteled"
thanks in advance.
here is my save method:
def savedoc(self, doc): c4d.StatusSetText ('Saving Document.') path = self.folderpath if doc.GetDocumentPath(): path = doc.GetDocumentPath() name = doc.GetDocumentName() # an unsaved doc has no extension we have to check if name[-4:] == ".c4d": newname = name # the user has his own document we dont change the name else: newname = name + "_imported.c4d" # the user has no document we give a little context # c4d does not update to _imported.c4d doc. #doc.SetName(newname) #c4d.documents.SetActiveDocument(doc) filename = os.path.join(path, newname) print ("Saving file to: ", filename) c4d.documents.SaveDocument( doc, filename, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST | c4d.SAVEDOCUMENTFLAGS_DIALOGSALLOWED, format=c4d.FORMAT_C4DEXPORT)
@mogh Did you try doc.SetDocumentName(newname)?
No stupid me, overlocked this ... thanks for the hint Frank.
