On 01/08/2003 at 05:35, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Language(s) : C++ ;
--------- Hi i wanted to upgrade my Pointcollapse Tool with a "only visible Points" mode so i have the problem of checking whether a point is visible. Does someone know if there is a way to use the Z-buffer for a visibility check. BaseDraw::TestPointZ(..) seems only to check if the Point is within the nearclip/farclip range. I could also use the RayCollider to check if there are polys in front of my point. Hope this is not too slow. Michael
On 01/08/2003 at 06:05, xxxxxxxx wrote:
Hi Michael, Z-Buffer...hmm, doubt this would be useable but not sure. With TestPointZ you are right, it doesn´t check for visibility somehow (maybe it´s buggy?) Cannot help you with the RayCollider though for I haven´t used it. Mikael will be back on Monday, I guess he can tell you more then. Good luck! (and let me know how you worked it out
On 02/08/2003 at 15:35, xxxxxxxx wrote:
A Z buffer test is for most purposes not a viable option - it's simply too imprecise. Also think of some gfx cards that do not allow to read GL Z values (though they have become rare). The best way is to send in rays to detect which points are visible and which not.
On 03/08/2003 at 00:36, xxxxxxxx wrote:
thank you guys ....but, now i would really like to try that z-test thing out I can hardly believe that it is too imprecise. Since it is precise enougth for drawing. so i would do someting like visible = ( Abs(p.z - buffer[p.x][p.y]) < small_value ) i think it would be enougth to filter out points that are far behind the visible surface. And for the ray test, there are two problems: there are some strange perspective projetions where i don't know where to start the rays. And i have to test every point against every poly... That is no good unless the point-polys-test is O(log n) i will think some more about it..
On 04/08/2003 at 04:26, xxxxxxxx wrote:
ok i'm using the ray shooting method now. It works quite well unless the mesh is not too big.
On 04/08/2003 at 17:18, xxxxxxxx wrote:
yes, I believe it is. But if it works..why not ;o) IMO there should be a convenience function in the SDK that returns only the visible points, just like we can get the selected, hidden points.
On 07/08/2003 at 15:58, xxxxxxxx wrote:
you could try the C4DObjectList class this seems to be the fastest way to get a z distance to a given point on screen. you can use it something like this AutoAlloc<C4DObjectList> mylist; SelectionListCreate(doc, NULL, bd, x, y, NULL, mylist); you will need to convert your world coords into screen coords. this will put a list of all objects that can be found at the screen coord x,y into mylist of course the first object is the nearest and you can read its z distance. the advantage of this is that you dont need to consider which objects are in the scene or how many. spline objects are passed as planes , so you should check through the list for the first valid polygon based object. im not sure if this is the right method for you plugin , but its a very fast and easy way to get z depth values and can be abused in many ways.
On 08/08/2003 at 00:16, xxxxxxxx wrote:
that is not necessary for my plugin since it should only consider "self" occlusion of the active object. Similar to the live selection tool.
On 08/08/2003 at 04:28, xxxxxxxx wrote:
You can't access C4D's Z buffer. There are lots of reasons it's not very practical to do so: the Z buffer may be in unititialized state, the Z scaling is different for the various display types, some GL buffers don't support Z access etc. Finally, as beaker said, its so imprecise. If C4D would use this for selection, you couldn't work with it. (All according to the developers.)
On 08/08/2003 at 05:33, xxxxxxxx wrote:
aha. then i was wrong i guess. but never mind. i build in ray shooting anyway. It was very easy with the raycollider. It's slow with large meshes but guess i can limit the number of point's that must be checked... in a future version.
