Solved Assign materials to Objects using Python Un-subscribe from this thread
Hello!
I would like to automate the replacement of materials loaded in Alembic.
How can I change the attached python code to replace the material with a material with the same name as the one applied in Alembic?
I would appreciate your advice.
I am new to the forum, so please forgive my unfamiliarity.
import re
  oplist = doc.GetObjects()
  if not oplist: return
  matlist = doc.GetMaterials()
  if not matlist: return
  if oplist:
      for op in oplist:
        opname = op.GetName()
        mat = doc.SearchMaterial(opname)
        if not mat:
          for mat in matlist:
              mname = mat.GetName()
        match = re.match(opname, mname)
        if match:
          textag = c4d.TextureTag()
          textag.SetMaterial(mat)
          textag[c4d.TEXTURETAG_PROJECTION]=c4d.TEXTURETAG_PROJECTION_UVW
          op.InsertTag(textag)
if __name__==‘__main__’:
hi,
welcome to the forum.
I would change the fact that if no material is found with the right name, we can just continue the loop with the next object.
This will add a new material tag to the alembic object and link the tag to the material. That is exactly what you want to do?
import re
  if not oplist:
  # Check if there is at leat one material in the document otherwise return
  mat = doc.GetFirstMaterial()
  if not mat:
  # we already checked if oplist is not empty we do not need it twice
  for op in oplist:
    # If there is no material with the same name, we can continue the loop to the next object
    if not mat:
      continue
    if match:
if __name__== '__main__':
Manuel
MAXON Registered Developer
hi,
import re
  if not oplist:
  if not mat:
  for op in oplist:
    if not mat:
      continue
    if match:
Manuel
Hello @Tomoya,
without any further questions or postings, we will consider this thread as solved by Friday the 4th, February 2022.
