SOLVED Toggle Only select Visible element.
Hello i wanted to toggle off and on the ‘Select only Visible elements’ and i know that there is an already build in shortcut for that on cinema, but it only toggles the tool you have active, i want it to toggle the lasso tool (Toggle Only select Visible element on it and the live selection tool in the same time ).while still being on the live selection tool so i came up with this script, this one does toggle only the active tool but i couldn’t make the jump to lasso tool and activate/deactivate there and then come back to live tool, really appreciate some guidance!
    tool = doc.GetActiveToolData()
    c4d.CallCommand(200000083) #Liveselection
    tool[c4d.MDATA_SELECTLIVE_VISIBLE] = not tool[c4d.MDATA_SELECTLIVE_VISIBLE] #Toggle Visible Selection
    c4d.CallCommand(200000084) #Lassoselection
    tool[c4d.MDATA_SELECTION_VISIBLE] = not tool[c4d.MDATA_SELECTION_VISIBLE] #Toggle Visible Selection
    c4d.CallCommand(200000083) #LiveselectionAgain
    doc.EndUndo()
# Execute main()
if __name__=='__main__':
I'm using S24.
I figured it out, it was a simple take but for a newbie like me, it was difficult.
Code :
Thank you, everyone.
Code :
Hi @akramFex , I apologize for the long silence on our side. Unfortunately the thread fell through the cracks of the Xmas period and we lost track of it.
I'm glad you were able to find the solution and I'm grateful you wanted to share it with the rest of the community.
Cheers, R
