I use ZipFile::CopyInFileInZip()
to compress the file into a zip package. However, when the file name contains non ASCII characters, the file name is replaced with an underscore. Is there a way to use non ASCII file names in zip without using external libraries?
AutoAlloc<ZipFile> zf;
if (zf == nullptr)
return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
if (!zf->Open(fnZip, false, ZIP_APPEND_CREATE))
return maxon::UnknownError(MAXON_SOURCE_LOCATION);
Filename fnCopy;
while (fnCopy.FileSelect(FILESELECTTYPE::ANYTHING, FILESELECT::LOAD, "Select file to add to Zip File"_s))
zf->CopyInFileInZip(fnCopy, "textures/" + fnCopy.GetFileString());
Thank,
AiMiDi
