Solved MSG_MENUPREPARE called twice for same object
When user creates an object by clicking on the menu item, MSG_MENUPREPARE is called twice in ObjectData::Message.
This happens only in C4D r25.113. Prior to this version, it was called only once. Is this behavior going to be permanent?
This is a known bug that is already corrected internally. The fix will be release as soon as possible. Sorry for the inconvenience.
So no, this is not a permanent change.
Manuel
MAXON Registered Developer
Manuel
Ok, great.
Thank you for the following info,
Regards,
Kristian
Hello @kikizg,
without any further questions or postings, we will consider this thread as solved by Friday the 4th, February 2022.
