UNSOLVED Get data about moving objects in c4d file
Here is a file in C4D format, and the object in the file is motion, and I want to get the pose of each frame in motion, or I want to read the data of key frames in the file, as shown in the figure
What should I do?
Just to be sure, you want to use Cineware and read that file from another software than Cinema 4D?
Manuel
Hi
I wanted to use the Cineware SDK, but could not find the relevant information!
Thank you!
hi,
This is like retrieving the information from a document inside cinema4D. You need to get the CTrack first, fromt that CTrack you can retrieve the CCurve and retrieve the values from CCurve.
To retrieve the information, you will need to understand the concept of DescID, check our manual about them. You can read our manual about CTrack You will find interesting manual about animation at this page
	const char* fn = "cube_anim.c4d";
	auto ExitError = [](const String& msg ) -> int
		printf("error : %s", msg);
		char value;
		printf("\n <press return to exit>");
		scanf("%c", &value);
		return 0;
	// check if the file exists
	if (!GeFExist(fn))
		ExitError("\n   file do not exist\n   aborting...");
	// in this document, i've got the first object that is a cube with several tracks with an animation of the cube moving along the Z axis.
	BaseDocument* doc = LoadDocument(fn, SCENEFILTER_MATERIALS | SCENEFILTER_OBJECTS);
	if (!doc)
		ExitError("no document found");
	BaseObject* cube  = doc->GetFirstObject();
	if (!cube)
		ExitError("no object found found");;
	// To retrieve the position.z track we need to define its DescID
	DescID trackID = DescID(DescLevel(ID_BASEOBJECT_REL_POSITION, DTYPE_VECTOR, 0), DescLevel(VECTOR_Z, DTYPE_REAL, 0));
	CTrack* cubeTrack = cube->FindCTrack(trackID);
	if (!cubeTrack)
		ExitError("no track found");;
	// Get the curve of that track
	CCurve* curve = cubeTrack->GetCurve();
	if (!curve)
		ExitError("no curve found");
	const Int32 docFPS = doc->GetFps();
	for (Int32 frame = 0; frame < 30; frame++)
		const BaseTime timeToSample = BaseTime(frame, docFPS);
		doc->SetTime(timeToSample);
		doc->Execute();
		const Float value = curve->GetValue(timeToSample);
		printf("value at this frame : %i   value  %i\n", frame, value);
	// display all values of all tracks
		// define the document's time and execute so everything update correctly.
		doc->Execute();
		// Retrieve the first track
		CTrack* track = cube->GetFirstCTrack();
		while (track)
			CCurve* trackCurve = track->GetCurve();
			if (!trackCurve)
				continue;
			const Float value = trackCurve->GetValue(timeToSample);
			// display the name of the track and the value sampled.
			printf("value of track %s at this frame : %i   value  %i\n", track->GetName().GetCStringCopy(STRINGENCODING::STRINGENCODING_8BIT), frame, value);
			track = track->GetNext();
	// to keep the console window open wait here for input
	char value;
Manuel
