Hi, I want to use my method to calculate the tangent and weight of the animation curve.
But I ran into a problem. I can’t know how the vector base of the coordinate system of the TimeLine panel is defined. In the 3D coordinate system, x=1 cm, y=1cm, z=1cm, but in the TimeLine panel, x= 1Frame ?1 second, y =1 cm?1%? or 1 Degree.
Thanks for any help!
Hello @chuanzhen,
thank you for reaching out to us. We are not quite sure how to interpret your question as the context is unclear to us.
1px == 1cm
Draw()
clip_left
clip_right
In case there are still open question for you, we would kindly ask you to reiterate your question to give us more clarity.
Cheers, Ferdinand
@ferdinand Thanks for your detailed reply! " 2.The timeline (and as a matter of fact also the world coordinate system) has no implied unit. There is no direct translation as 1px == 1cm as both the horizontal axis and vertical axis depend on the zoom level." solved my question!
