Help ... I don't get that with the * .res files, dialogs etc So to internalize that: A dialog is when I press a command for example and a window opens ... the res files belong in the dialogs folder And with an object plugin e.g. or tag plugin, the parameters for setting, these are descriptions and these res files belong in the description folder
I'm so stupid, it really depresses me ... I also copied the example files for the test, didn't change anything ....
I would like to create a very simple object plugin that simply creates a cube for the beginning and provides a real parameter that sets the side lengths ..... The plugin loads, the cube is displayed but my parameters and my group are not .... what am I doing wrong ..... the manuals for Python are confusing, dialogs are shown, but not for descriptions .....
This is the code for the plugin
import c4d import os PLUGIN_ID = 1000001 #test ID class Cube_Maker(c4d.plugins.ObjectData): def Init(self, node): self.cube = c4d.BaseObject(c4d.Ocube) self.cube.SetPhong(True, True, c4d.utils.DegToRad(45)) return True def GetVirtualObjects(self, op, hh): return self.cube def GetDimensions(self, op, mp, rad): # I don't know just tried :-) mp = c4d.Vector(40) rad = c4d.Vector(40) return if __name__ == "__main__": path, file = os.path.split(__file__) fn = os.path.join(path,"res","window_maker.tif") bmp = c4d.bitmaps.BaseBitmap() bmp.InitWith(fn) checker=c4d.plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="Cube", g=Cube_Maker, description="", icon=bmp, info=c4d.OBJECT_GENERATOR) if checker: print("Window Maker Ready")
this is the code for the MYDIALOG.h file:
#ifndef _MYDIALOG_H_ #define _MYDIALOG_H_ enum { SIDE = 1001 } #endif
this is the code for the MYDIALOG.res file:
CONTAINER MYDIALOG { NAME MYDIALOG; INCLUDE Obase; INCLUDE Mpreview; GROUP CUBE_PROPERTIES { REAL SIDE{ UNIT METER; MIN 0.0; } } }
this is the code for the MYDIALOG.str file:
STRINGTABLE MYDIALOG { MYDIALOG "Cube-Maker"; SIDE "Side-Length"; }
and the c4d.symbols file:
enum { // string table definitions _DUMMY_ELEMENT_ };
here is my PluginStructure:
The plugin at the moment starts, loads ..I just want to show the group and the parameter , for the start without any function...just a real value
I am aware that I am sure that I am doing a lot wrong and that I have forgotten some things ... but the plugin concept is completely new to me ...
Sincerely Tom
So I figured it out....
this f....... res , header and str. files concept ....I hate it.... also you have to initialize the parameter in the plugin , too..... double work......
so now it works
res file:
CONTAINER OCUBO { NAME Cube; INCLUDE Obase; //INCLUDE Mpreview; GROUP ID_OBJECTPROPERTIES { REAL SIDE{ UNIT METER; MIN 0.0;} } GROUP IHATEIT { REAL LENGTH{ UNIT METER;} } }
.h-file
#ifndef _OCUBO_H_ #define _OCUBO_H_ enum { //Ocubo = 1000001, SIDE = 1001, // link [just for compatibilty <V9.200] IHATEIT=1003, LENGTH = 1002, } #endif
.str file
STRINGTABLE Ocubo { Cube "Settings"; SIDE "Side-Length"; LENGTH "Length"; IHATEIT "Hate this"; }
That is correct, dialogs and descriptions must be stored in different directories.
When registering the plugin, you need to specify the description file used by the plugin. That's how the plugin is "linked" to the resource file. See our documentation here
checker=c4d.plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="Cube", g=Cube_Maker, description="MYDIALOG", icon=bmp, info=c4d.OBJECT_GENERATOR)
You can also have a look at our github repository where you will find some examples of plugins where we use dialog and description.
I didn't test your code but that is what jumped to my eye directly.
By the way, calling your description file "MYDIALOG" is not the best idea.
Also, in your code, you are creating the cube on the Init function and returning it in GetVirtualObject. That's not the right way of doing it. Everything should be done inside GetVirtualObject.
Cheers, Manuel
@m_magalhaes
OK thank you, yes I already tried that with the GetVirtualObject.....but can I do my own init function? anyways....
I changed the description now to my res filename....but he shows me now an error in line 9 in resfile, after calling the "plugin" in Cinema.
In the meanwhile I just changed the filename and the names etc.
CONTAINER CUBE_SETTINGS { NAME cube_object; INCLUDE Obase; INCLUDE Mpreview; GROUP ID_CUBE_PROPERTIES { GROUP { REAL SIDE{ UNIT METER; MIN 0.0; } } } }
Sincerely Thomas
@thomasb said in Help needed * .res files, dialogs etc...Plugin beginner:
yes you can, specially if you want to initialize some variable. But you should not create any geometry there and return this geometry in GVO (get virtual object).
About the group, there's a note about it here. Each NodeType have a "parent" group. Glad that it is working now.
