Primitive Text Object
On 27/07/2003 at 22:35, xxxxxxxx wrote:
Cinema 4D Version:   7.303
Platform:   Windows  ;
I want to change the text string value of a Primitive Text Object. I used the following code.
    if(vObj->GetPrimitiveType()==1017) // if TEXT Object
       var bc=vObj->GetContainer();
       bc->SetData(PRIM_TEXT_TEXT, "Change");
       vObj->SetContainer(bc);
    GeEventAdd(DOCUMENT_CHANGED);
    GeEventAdd(REDRAW_ALL);
Even though I use GeEventAdd(), I cannot see the new text, still it shows the old text. But from the object manager when I check, it has changed the text with new one. What could be the problem?
On 28/07/2003 at 06:00, xxxxxxxx wrote:
did you try vObj->Message(MSG_UPDATE); ?
I´m kind rusty concerning COFFEE but it should work :)
On 28/07/2003 at 20:36, xxxxxxxx wrote:
Yes, it works now.
Thanks Samir.
