Hello. I recently hopped from R21 to R25 and noticed some weird behaviors with R25.
If I create a modal dialog with a color field in it and try to open the color picker window by clicking the color field, it doens't open in R25. This works in R21.
Code for the modal dialog setup:
import c4d from c4d import gui from c4d.gui import GeDialog # Classes class Dialog(GeDialog): def __init__(self): super(Dialog, self).__init__() self.res = c4d.BaseContainer() # Create Dialog def CreateLayout(self): self.SetTitle("Dialog") self.GroupBegin(1000, c4d.BFH_CENTER, cols=1, rows=1, groupflags=1, initw=125, inith=0) self.GroupBorderSpace(5, 5, 5, 5) self.AddColorField(2002, c4d.BFH_FIT, initw=70, inith=13, colorflags=c4d.DR_COLORFIELD_POPUP) self.SetColorField(2003, c4d.Vector(0,0,0), 1, 1, c4d.DR_COLORFIELD_ENABLE_COLORWHEEL) self.GroupEnd() return True # Functions def main(): dlg = Dialog() # Create dialog object dlg.Open(c4d.DLG_TYPE_MODAL, 0, -1, -1, 0, 0) # Open dialog # Execute main() if __name__=='__main__': main()
When creating an asynchronous dialog, the color chooser window will pop up correctly.
Code for the async dialog setup:
import c4d from c4d import gui from c4d.gui import GeDialog # Classes class Dialog(GeDialog): def __init__(self): super(Dialog, self).__init__() self.res = c4d.BaseContainer() # Create Dialog def CreateLayout(self): self.SetTitle("Dialog") self.GroupBegin(1000, c4d.BFH_CENTER, cols=1, rows=1, groupflags=1, initw=125, inith=0) self.GroupBorderSpace(5, 5, 5, 5) self.AddColorField(2002, c4d.BFH_FIT, initw=70, inith=13, colorflags=c4d.DR_COLORFIELD_POPUP) self.SetColorField(2003, c4d.Vector(0,0,0), 1, 1, c4d.DR_COLORFIELD_ENABLE_COLORWHEEL) self.GroupEnd() return True # Open async dialog dlg = Dialog() # Create dialog object dlg.Open(c4d.DLG_TYPE_ASYNC, 0, -1, -1, 0, 0) # Open dialog
Is this a known bug or is something changed in the SDK that I should accomplish this an another way?
Btw, also the color picker doesn't work in the R25's color chooser window.
I'm running Cinema 4D R25.010 Windows 10 (21H1)
Cheers, Arttu
as we replaced the behaviour of the color chooser in R25 (it's no more a Modal dialog) you cannot open it from a Modal dialog anymore.
This is a limitation/bug for now. I've opened a bug report.
Cheers, Manuel
Hi, thanks for the information. Hopefully it will get fixed in the future updates.
