Hi, in picture object Position gui unit is real, Rotation gui unit is Degree , User data gui unit is Percent. how to know gui unit? and how to directly obtain the value displayed on the panel(Data = 0.1745, want to directly get 17.453)?
Thanks for any help!
Hello @chuanzhen,
thank you for reaching out to us. I will answer in bullet points, since there are sort of two questions within you question.
BaseContainer
c4d.DESC_UNIT
Cheers, Ferdinand
The example code:
"""Attempts to evaluate the unit type of the first user data parameter of the currently selected object. Must be run in the Script Manger while having an object selected with at least one user data parameter. When the parameter has one of the unit types float, percent, degree or meter (there are other unit types), it will print out a matching message. If not, it will report that there is "another" unit type or no unit type when the parameter has no unit type set at all. """ import c4d def main() -> None: """Attempts to evaluate the unit type of the first user data parameter of the currently selected object. """ # op is a predefined module attribute in scripts referencing the currently # selected object. if not isinstance(op, c4d.BaseObject): raise RuntimeError("Please select an object.") # The id of the parameter we are interested in, the first user data # parameter of a node. pid = (c4d.ID_USERDATA, 1) # Get the description of the node. description = op.GetDescription(c4d.DESCFLAGS_DESC_NONE) # Get the first user data element in the description. parameterData = description.GetParameter(pid) # Bail when the container is empty, i.e., there is no such parameter in # the node. if len(parameterData) < 1: raise RuntimeError(f"Retrieved empty data container for {pid}.") # How to iterate over the flags of that parameter container. # for cid, value in data: # print (cid, value) # Get the unit type flag for the element and bail if there is no value # set for that flag. unitType = parameterData[c4d.DESC_UNIT] if unitType is None: print (f"The parameter with the id {pid} has no unit type.") return # Do some stuff depending on the unit type. if unitType == c4d.DESC_UNIT_FLOAT: print (f"The unit type for {pid} is float.") elif unitType == c4d.DESC_UNIT_PERCENT: print (f"The unit type for {pid} is percent.") elif unitType == c4d.DESC_UNIT_DEGREE: print (f"The unit type for {pid} is degree.") elif unitType == c4d.DESC_UNIT_METER: print (f"The unit type for {pid} is meter, i.e., length.") else: print (f"The unit type for {pid} is another unit type.") if __name__ == '__main__': main()
@ferdinand Thanks,great!
