Solved Noob wants to load custom palette
Hi everybody,
I am trying to load a custom palette via python script and an absolute file path using R25, which should then be assigned to a keyboard shortcut.
This experiment gives me a syntax error:
from c4d import gui
    c4d.documents.LoadFile(C:/Users/User/Desktop/HB_Layout/palette_Basictools.l4d)
if __name__=='__main__':
    main()`
Please give me some help.
Your file name / path is missing the quote marks.
(Can't check the indents as the code is not properly formatted.)
@cairyn Thanks a lot ... it works!
