Dear Developers,
So I have this Class for a dynamic settings and help interface which works fine see code below. Here are the list of what is not included
Emm Code works for all versions from R21 - S25 Tested
See how it works in the gif below
it does just that it all works see the code below, After code contains the problem pls scroll down
# ID's # 1. Main Group That Holds ALl The Other Grooups ID_MAINGROUP2 = 19000 ID_SUBMAIN = 19500 # 2.LeftBox Group and CheckBox LB_GROUP = 3000 LB_USE_CUSTOM_COLOR = 3001 LB_TOGGLE_GLOW = 3002 # 3.RighBox Group and COMBObox COMBO_GROUP = 4000 COMBO_BOXID = 4003 COMBO_USE_ASV = 4004 COMBO_USE_ARV = 4005 # 4. Info INFO_GROUP = 5000 INFO_TEXTF = 5001 # Ok/Cancle BTN_GROUP = 7000 BTN_OK = 7001 BTN_CANCEL = 7002 # End of ID's class Settings_Gem(gui.GeDialog): """docstring for Settings""" def __init__(self): super(Settings_Gem, self).__init__() self.res = c4d.BaseContainer() def InitValues(self): print ("Refreshing GUI") defaultMSG, Msg1, Msg2, Msg3, Msg4 = SMsg() self.AppendGuiHelp(defaultMSG) return True def AppendGuiHelp(self, msg): replace(1, msg) # Flush the content of the group that holds all ours SubDialogs self.LayoutFlushGroup(INFO_GROUP) self.AddMultiLineEditText(INFO_TEXTF, c4d.BFH_SCALEFIT, inith=50, initw=500, style=c4d.DR_MULTILINE_READONLY | c4d.DR_MULTILINE_WORDWRAP) self.GroupEnd() # GUISettings,Camera,Comp,Focal,Toggle = loadSettings() GUISettings = loadSettings() txt = str(GUISettings["setINFO"]) txtfix = (txt.format("\n")) self.SetString(INFO_TEXTF, txtfix) # Notifies the content of the MainGroup has changed self.LayoutChanged(INFO_GROUP) return True def CreateLayout(self): bc = c4d.BaseContainer() # Initialize a base container self.SetTitle("Settings For SetCamS") # Set dialog title # ---------------------------------------------------------------------------------------- self.GroupBegin(ID_MAINGROUP2, c4d.BFH_LEFT, 1, 2) self.GroupBorderSpace(5, 5, 5, 5) # ---------------------------------------------------------------------------------------- self.GroupBegin(ID_SUBMAIN, c4d.BFH_FIT | c4d.BFH_LEFT, 4, 1) # self.GroupBorderSpace(5, 5, 5, 5) # self.GroupBorderNoTitle(c4d.BORDER_ACTIVE_3) # Check Box On Left self.GroupBegin(LB_GROUP, c4d.BFH_LEFT, 1, 1, "") self.GroupBorderNoTitle(c4d.BORDER_ACTIVE_4) self.GroupBorderSpace(5, 5, 5, 5) self.AddCheckbox(LB_USE_CUSTOM_COLOR, c4d.BFH_LEFT, 0, 13, "Use Custom Color") self.AddCheckbox(LB_TOGGLE_GLOW, c4d.BFH_LEFT, 0, 13, "Last Used Show Glow") self.GroupEnd() # Check Box On Right self.GroupBegin(COMBO_GROUP, c4d.BFH_RIGHT, 2, 1, "Cam Mode") self.GroupBorder(c4d.BORDER_ACTIVE_4) self.GroupBorderSpace(25,13, 25, 13) self.AddComboBox(COMBO_BOXID, c4d.BFH_RIGHT, 140, 13) self.AddChild(COMBO_BOXID, COMBO_USE_ASV, "Use ASV") self.AddChild(COMBO_BOXID, COMBO_USE_ARV, "Use ARV") self.GroupEnd() # End 'Alt' group self.GroupEnd() # Creates a group that will contain all the group representing each tab # self.GroupBegin(ID_MAINGROUP, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, '', 0) # self.GroupEnd() self.GroupBegin(INFO_GROUP, c4d.BFH_RIGHT, 2, 1, "INFO") self.GroupBorder(c4d.BORDER_ACTIVE_4) self.GroupBorderSpace(5, 3, 5, 3) self.AddMultiLineEditText(INFO_TEXTF, c4d.BFH_SCALEFIT, inith=50, initw=500, style=c4d.DR_MULTILINE_READONLY | c4d.DR_MULTILINE_WORDWRAP) # self.SetString(INFO_TEXTF, # "Pls Read!!! \nThis Shows You What Each Setting you Clicked On is Used For." # "\nDon't Ask Why! :| I Am Real Bad At Naming Sh*&" # "\n\nHold CTRL and Run the Script to Ignore All Selected Camera Obj(s), This will Apply any SetCam Script Settings to you C4D Default Camera\n" # "The Default Camera Selected is Based on the ASV/ARV in the Settings GUI.") self.GroupEnd() self.GroupBegin(BTN_GROUP, c4d.BFH_CENTER, 0, 0, "OK to SaVe Settings") # Begin 'Buttons' group self.GroupBorder(2) self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL) self.GroupEnd() # Set Defaults GUISettings = loadSettings() # GUISettings,Camera,Comp,Focal,Toggle = loadSettings() txt = str(GUISettings["setINFO"]) txtfix = (txt.format("\n")) self.SetString(INFO_TEXTF, txtfix) self.SetInt32(LB_USE_CUSTOM_COLOR, int(GUISettings['setC_Color'])) self.SetInt32(LB_TOGGLE_GLOW, int(GUISettings['setT_Glow'])) self.SetInt32(COMBO_BOXID, int(GUISettings['setCOMBO'])) return True def Command(self, id, msg): bc = c4d.BaseContainer() # Initialize a base container defaultMSG, Msg1, Msg2, Msg3, Msg4 = SMsg() ##################### # Save, Cancle, Esc # ##################### C_Color = int(self.GetInt32(LB_USE_CUSTOM_COLOR)) # Get color T_Glow = int(self.GetInt32(LB_TOGGLE_GLOW)) # Get glow Combo = int(self.GetInt32(COMBO_BOXID)) # Get Camera COMBO c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ESC, bc) if bc[c4d.BFM_INPUT_VALUE]: print("User Click on ESC") self.Close() return True # User click on Ok button if id == c4d.DLG_OK: print("User Click on Ok") saveSettings(C_Color, T_Glow, Combo) self.Close() return True # User click on Cancel button elif id == c4d.DLG_CANCEL: print("User Click on Cancel") # Close the Dialog self.Close() return True # print (id) ############################ # Staring To Write to File # ############################ if id == LB_USE_CUSTOM_COLOR: print ("Settings CustomCOlor") self.AppendGuiHelp(Msg1) return True if id == LB_TOGGLE_GLOW: print ("Settings ToggleGlow") self.AppendGuiHelp(Msg2) return True if id == COMBO_BOXID: if Combo == COMBO_USE_ASV: print ("Settings ASV") self.AppendGuiHelp(Msg3) return True elif Combo == COMBO_USE_ARV: print ("Settings ARV") self.AppendGuiHelp(Msg4) return True else: print ("WHF") self.AppendGuiHelp("Hahaha open a Fucking") return True diag = Settings_Gem() diag.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, 0, -2, -2, 200, 45) # Open dialog
Problem, Now I made a simple popUp dialog and copy pasted the Settings class just as it is and called it
if result == Settings_id: diag = Settings_Gem() diag.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, 0, -2, -2, 200, 45) # Open dialog
And It's a disaster sometimes I get a SystemError: error return without exception set "Which is Fustrating" or worse See gif
The whole thing just Falls Apart I would have pasted the whole code but it's like 2k line plus since it a completion of multiple Things all in one.
Ohh and the .ini File does update only the Gui in cinema4D does not
Thanks for your prompt Reply, I was able to debug the whole thing yesterday, I don't know what to do with this post now though.
Hello @eazy5d,
welcome to Plugin Café and the Cinema 4D development community. Thank you for reaching out to us.
We are having some troubles answering your question, since neither your code is executable (I can see that the import statements and the registration calls for your CommandData are missing for example) nor is your problem description 'And It's a disaster sometimes I get a SystemError: error return without exception set "Which is Fustrating"' fully clear to me. So, you mean an exception is being raised without a callstack or what does 'SystemError: error return without exception set' mean? Without any line-numbers it is hard to unpack that. Which would make executable code important.
CommandData
So, we would ask you to provide the full content of your '*.pyp' file, so that we can test your plugin ourselves. It would also be good, if you could provide a short description of what actions lead to your problem. I think you did intended to describe that with an image, but the image below 'or worse See gif` seems to be the same as the first one you did post and at least for me does not bear any indication on what is going wrong.
Cheers, Ferdinand
