Hi everyone,
I'm trying to add my own color preferences and add them to the "Scheme Colors" section in the Cinema 4D preferences, similarly to what Hair does.
To do so, I successfully add and register a PrefsDialogObject. I used a description similar to the Hair one in prefshaircolor.res/prefshaircolor.h and it displays fine. The implementation is based on an earlier thread from the forum (and a bit of prior experience): https://plugincafe.maxon.net/topic/11737/default-startup-settings/4
PrefsDialogObject
prefshaircolor.res
prefshaircolor.h
It works pretty much fine, the preferences show up in the right place and I am able to control the colors in the list view the same way it works in all the other color preferences. I even added that "Reset..." button. The only problem is that the data in the ListViewData element does not appear to be restored properly when Cinema 4D starts up again. I tried other data types like Int32 and those are brought over into a new session just fine.
ListViewData
Int32
When looking at the BaseContainer with my Plugins' settings I see that when I call BaseContainer::GetData() on it, the resulting GeData is of type DA_MISSINGPLUG, which to me looks like Cinema 4D is somehow not able to restore the data element from the preferences. It looks a little like that might be because the ListViewData custom datatype hasn't been registered when the preferences are restored?
BaseContainer
GeData
DA_MISSINGPLUG
However, I am assuming that the regular Cinema 4D color scheme preferences somehow store their setting and when loading the Hair preferences via HairLibrary::GetPrefsInstance(), I see the container it returns contains elements of type CUSTOMDATA_LISTVIEW (1018397), so it somehow must be possible to store values of that type in the preferences.
CUSTOMDATA_LISTVIEW
Did anybody run into similar problems before and can help me? I'm feel like I must be missing something trivial here.
Thanks in advance for any help!
Best Timm
Hi @tdapper, the hair color preferences are automatically loaded from a file during C4DPL_STARTACTIVITY and saved within C4DPL_ENDACTIVITY, So you will need something similar for your plugin to properly serialize and load data.
C4DPL_STARTACTIVITY
C4DPL_ENDACTIVITY
If you still have issue, could you share your code, so we can have a look of what is wrong. Thanks in advance, Cheers, Maxime.
Hello @tdapper ,
Without any further questions, we will regard this topic as solved and flag it accordingly by Monday, September, the 8th.
