Hello! I develop my plugin on C++ and trying to receive the same line of Python code:
matrixA= c4d.utils.MatrixMove(c4d.Vector(0,10,0)) matrixB = myObject.GetMg().__mul__(matrixA)
MatrixMove func exists in a C++ help. But I can't find in C++ help the analogue of .mul function.
So does this function from a Python help: https://bit.ly/30dc2Ps https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d/Matrix/index.html?highlight=mul#Matrix.mul
exists for a C++?
Hello @yaya,
matrixB = myObject->GetAbsPos() * matrixA;
First of all, BaseObject::GetAbsPos returns a Vector, which in turn makes your calculation at least implicitly wrong, since you call the result matrixB, implying that it is a matrix. But the product of a matrix M and a vector p is the vector p' transformed by M. There is also the fact that order matters in the C++ SDK, i.e., you are forced to write expressions in the canonical matrix-first order (in Python you are not restricted in such fashion, because Python handles operator overloading differently).
Vector
matrixB
Vector p; Matrix M; // Valid expression since Mat3 has an operator overload for M * p Vector q = M * p; // Invalid expression since Vec3 does not have an operator overload for p * M Vector r = p * M;
It might also be noteworthy that Matrix and Vector are only aliases originating from our classic API. The types have been replaced by a more versatile templated model of the atomic arithmetic types. Vector is just a typedef for maxon::Vec3<maxon::Float64, 1> and Matrix for maxon::Mat3<maxon::Vector64>. You can find the relevant template descriptions in the Mat3< V > Struct Template and Vec3< T, STRIDE > Struct Template references.
Matrix
typedef
Cheers, Ferdinand
operator * does not work for you?
Hi, Cairyn is right, the operator you are looking for is *
Cheers Manuel
@m_magalhaes @Cairyn
Hello guys. No, the simple operator * between two matrixes shows an error. Right now I've write it like this:
also via operator*.
But I am not sure will GetAbsPos return the same (according I need only the position offset of matrix).
Hello @ferdinand
Thank you for a such detailed answer. It is hard for me to understand all of it by eye, and I can't say right now is it what I search. I need to receive in the result the point in 3d space which is attached to another point like it is a child of parent (only position is needed).
So all construction serves to achieve a Vector point of a new position shifted by 10 units in a one of its local axis. (Vector(0,10,0))
I will finish my python-C++ rewriting and will test your example above. Thank you!
Hello @ferdinand I've tested it a bit and now I've finished with this:
instead of this:
to this:
Matrix matrix = MatrixMove(Vector(0, 10, 0)); Vector vector = myObject->GetMg() * matrix.off;
It looks it works for me. Thank you again!
