I am trying to write a script for the sketch material that makes the "pixel" mode in Draw Speed in the Animate tab work similar to the "completion" mode. What I mean by that is that I want to be able just like in the completion mode to keyframe the beginning and end of the drawing process. But the pixel mode only lets me set the start frame and the speed in pixels.
So the goal is to have the script calculate the speed required to make the drawing end at frame x.
The reason for doing this is that if I have objects with multiple different strokes of different lengths, the drawing speed varies significantly which doesn't make for a nice aesthetic in the end.
I know there has to be some place in C4D where the length of each stroke is stored in order for the completion mode to work. So the only question is if and how I could access this value in my python script.
Thank you.
