SOLVED Enabling Team Render in Render Queue
Hi- I have a python script that adds projects to the render queue successfully but now I'd like to be able to enable the Team Render option for them. After reviewing the documentation I felt like BatchRender.SetUseNet(self, n, on) was going to be the answer but I havn't been able to get it to work.
In the main body of the script I set dBatch = c4d.documents.GetBatchRender().
Later in the script I call batchRender definition.
def batchRender(dFilePath, objName):
    dBatchCount = dBatch.GetElementCount() #number of items already in the batch render
    dBatchCount += 1
    dBatch.AddFile(dFilePath +"/" + objName + ".c4d", dBatchCount)
    ####enable Team Render for item
    dBatch.SetUseNet(dBatchCount,True)
The script doesn't return any errors but the Team Render box is never activated.
Any insight is appreciated.
Thanks,
.del
For now, it look more like a bug. I need to figure out why before creating a bug entry.
I found out that if you add the files first and after in another loop enable them to use teamrender, it works a lot better.
Could you please check if it could fix your issue?
for index, file in enumerate(c4dFiles):
           br.AddFile(file, br.GetElementCount())
       for index in range(0, br.GetElementCount()):
           br.SetUseNet(index, True)
cheers,
Manuel
Thanks Manuel. I was able to work that concept into the overall script.
