Hello guys! I know how to merge a scene with a current project. But i have no idea how to insert scene under parent with coordinats of this parent.
I want to create custom nulls thats why i want to it. What should i add in this code if i want insert scene under object?
import c4d def main(): doc.StartUndo() # Start recording undos path = "C:\Users\Jamaletdinov.r\Desktop\ArrowR.c4d" flags = c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS | c4d.SCENEFILTER_MERGESCENE c4d.documents.MergeDocument(doc, path, flags) c4d.EventAdd() doc.EndUndo() if __name__=='__main__': main()
There's no direct way of doing that. I see two possibilities:
The problem is, as you can see on this thread, that some parameters of the xref are not accessible with python. The problem with links can be handle with AliasTrans.
Cheers, Manuel
hi,
hoo thanks a lot @mikeudin I somehow didn't though about this one xD
Mike, thank you a lot!
