Just FYI ... I just noticed, that a Quicktab Radio UserData change results in two Messages (with the same UserData ID) If I change the interface to Cycle, I get only one Message as expected for an UserData change.
This might be a tiny miny Bug (?)
index
Thanks for your bug report, it will be looked at but with low priority.
Cheers, Maxime.
Hello @indexofrefraction,
without further questions or replies, we will consider this topic as solved by Thursday and flag it accordingly.
Just for clarification: This does not mean that the bug is solved or that we won't track it, we simply do not want to keep the thread open until the bug has been fixed. The bug status is tracked with the to fix tag that has been added to the topic. We will report back here when the bug has been fixed.
to fix
