Hi all,
I'd like to ask a few questions to establish the basics on using basecontainers.
uniqueID = 12345 bc = c4d.BaseContainer() bc[12345] = "My new value" obj.SetData(bc, True)
There's nothing really stopping anyone from overwriting this id, so I was wondering if this is how the unique id is being used.
bc = c4d.BaseContainer() bc[12345] = (1,2,3,4,5) obj.SetData(bc, True) print (op.GetData())
This produces this error:
TypeError: could not convert 'tuple'
bc = c4d.BaseContainer subContainer = c4d.BaseContainer subcontainer[0] = "My subcontainer value" bc[12345] = subcontainer
Thanks in advance
Hi Orestis hope you are fine
Unique ID are registered in plugincafe. The only purpose is to be sure to not override existing data, but it's true there is nothing in the API preventing any other developer to not read/override the value you defined. But it's a good practice that every developer follow.
Correct only Cinema 4D Datatype can be used. To be more precise, only type registered with RegisterCustomDataType In C++. This registered type can then be stored within a GeData (GenericData) that can be handle by a BaseContainer. There is the method BaseContainer.GetType to inform you about the type of a value, and you can look at DTYPE enum to find some possible value, but again since any registered Custom Datatype can be used, this is not an exhaustive list.
Correct
Cheers, Maxime.
Hi @orestiskon,
From what I learnt recently, if you have more than one data to store, you can create a sub container of the base container identified by the pluginID.
I can't remember where I read that... just be careful I'm not an advanced C4D developer
In a class for a BaseTag I use this like that,
self.bcDATAS = c4d.BaseContainer() self.bcDATAS[ myData ] = "A string for example" # Be sure to use a unique ID obtained at https://plugincafe.maxon.net/c4dpluginid_cp myPLUGIN_ID = 0123456789 # Get the Document Settings BaseContainer self.bcDoc = doc.GetDocumentData( c4d.DOCUMENTSETTINGS_DOCUMENT ) self.bcDoc[ myPLUGIN_ID ] = self.bcDATAS # Store plugin container inside the document container # Save the updated Document BC op.SetData( self.bcDoc ) # To retrieve a data print ( op.GetData()[ myPLUGIN_ID ][ myData ] )
Christophe
@m_adam Thanks for the information Maxime.
@mocoloco interesting example, I didn't think about the document. I have a question:
Shouldn't that be:
doc.SetData(bcDoc)
Also, any reason you're using "self" before each variable?
@orestiskon, self is used because the example is an extract of a class. In my case, those variables are defined in the def __init__ (self):, and belongs to the class object. They are not globals. Have a look there, https://docs.python.org/3/tutorial/classes.html you will understand it with a much better explanation than mine.
If you plan to do not use that inside a class, you can get rid of self of course. Just be careful of doc and op used here below as they are arguments of def Execute(self, tag, doc, op, bt, priority, flags): used in my BaseTag plugin.
self
doc
op
Knowing this, I assume you can easily transpose this to your purpose as the following example won't work as it is
bcDATAS = c4d.BaseContainer() bcDATAS[ myData ] = "A string for example" # Be sure to use a unique ID obtained at https://plugincafe.maxon.net/c4dpluginid_cp myPLUGIN_ID = 0123456789 # Get the Document Settings BaseContainer bcDoc = doc.GetDocumentData( c4d.DOCUMENTSETTINGS_DOCUMENT ) bcDoc[ myPLUGIN_ID ] = bcDATAS # Store plugin container inside the document container # Save the updated Document BC op.SetData( bcDoc ) # To retrieve a data print ( op.GetData()[ myPLUGIN_ID ][ myData ] )
Hello @orestiskon,
without any further replies or questions, we will consider this thread as solved by Thursday and flag it accordingly.
Thanks Ferdinand, I'll mark this as solved.
thank you for flagging the topic as answered.
Cheers, Ferdinand
