Hi!
At some point the "Plugins" menu was renamed to "Extensions" and with it the ID of the actual menu. It used to be IDS_EDITOR_PLUGINS, but is now IDS_EDITOR_PIPELINE. Because of that c4d.gui.SearchPluginMenuResource() doesn't find it anymore without specifiying the identifier.
IDS_EDITOR_PLUGINS
IDS_EDITOR_PIPELINE
The default value (or even the function name) should probably be updated to reflect the change. (Or for the time being maybe just give a warning in the documentation?)
Hi the fix of the default value is already on its way and will be included in the next release pack
Cheers, Maxime.
Hi @Boony2000 with the latest update of Cinema 4D (R24 SP1), c4d.gui.SearchPluginMenuResource default value was fixed in Python.
