Hey SDK team, I have a little problem with polygon index.
I'm looking for an Idea how to select the polygon (index) front in the target object (spl or poly). Does anybody have an idea how to find this index of polygon ?
Thanks a lot!
edit: In my head it sounds like this: i find the position of each polygon and compare with the position of the pointer object and then find the polygon index which is closest
edit 2: Do I need to use this post(https://developers.maxon.net/?p=194) in my case or is there another way?
note: I, @ferdinand, did consolidate your postings
Hey Ferdinand, thank you for your answer. Yes, I'll be more accurate in my posts. I found a solution like this, but I would like to clarify if it is optimal?
def main(): tobj = op[c4d.ID_USERDATA,1] tpos = tobj.GetMg().off cobj = c4d.BaseObject(c4d.Ocube) cobj[c4d.PRIM_CUBE_LEN] = c4d.Vector(60, 60, 60) newobjList = utils.SendModelingCommand( command = c4d.MCOMMAND_CURRENTSTATETOOBJECT, list= [cobj.GetClone()], mode=c4d.MODELINGCOMMANDMODE_ALL, doc = doc) obj = newobjList[0] objmg = obj.GetMg() polyindex = obj.GetAllPolygons() polys = obj.GetPolygonS() centerlist = [] for p in polyindex: ptA = obj.GetPoint(p.a) ptB = obj.GetPoint(p.b) ptC = obj.GetPoint(p.c) ptD = obj.GetPoint(p.d) polycenterlp = (ptA + ptB + ptC + ptD)/4 polycentergp = polycenterlp * objmg centerlist.append(polycentergp) distlist = [] for c in range (len(centerlist)): vec = centerlist[c] - tpos dist = abs(vec.GetLength()) distlist.append(dist) mindist = min(distlist) for i in range (len(distlist)): if mindist == distlist[i]: polys.Select(i) bc = c4d.BaseContainer() bc.SetData(c4d.MDATA_SUBDIVIDE_SUB, 1) c4d.utils.SendModelingCommand(c4d.MCOMMAND_SUBDIVIDE, list = [obj], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc=bc, doc = doc) obj.Message(c4d.MSG_UPDATE) c4d.EventAdd() return obj
Hello @inevestenko,
thank you for reaching out to us. Please note that we require users to add information relevant to solving a question to their topics with tags. You can read more about tags in the Forum Guidelines. I have already added the Python tag for you, which I did assume from the context and prior postings of yours to be the programming environment. Please add the missing version and OS tags, since we will need them if we decide to provide example code. Please note also that the scope of support is limited to Cinema 4D SDK questions as stated in our forum guidelines. Your question is effectively a math and algorithmic question. Which is therefore out of scope of support. You might get community answers here, but we, Maxon, cannot help you through every step of the way.
That aside, a few points:
The Cinema 4D Python SDK does not offer you much which would help you here (the C++ SDK on the other hand has quite a few interfaces which would help). What you could use in Python is c4d.utils.ViewportSelect, although that would very much be an unintended usage. It is intended to carry out selections in a viewport. When you align the view transform, the camera, of a viewport with your plane gizmo, you could (try to) use it to retrieve the closest polygon. The method to retrieve the closest polygon, ViewportSelect.GetNearestPolygon does operate however with screen coordinates, as it is intended to handle mouse inputs, which makes this route unpractical.
The most simplistic interpretation of computing the distance would be to simply pick a query point p, then compute the polygon center points by taking the arithmetic mean of their vertices. The distance for each (p, center point) tuple is then the length of the vector difference of the two, e.g., dist_3 = (center_point_polygon_3 - p).GetLength(). To find the closest point in a polygon, i.e., not just pick the center point, you will have to do point plane projections. Assuming a mesh of triangles, project the query point onto plane defined by the triangle, using the dot product. Bring the projected point into barycentric coordinates and clamp them to the range [0, 1] which then will be the closest point q. Convert the barycentric coordinates back to cartesian and compute the distance between p and q. As before, do that for all polygons to find the closest one.
Helpful in this context might also be c4d.utilsNiehgbor. The more advanced acceleration data structures to make such computations fast, e.g., the Binary Space Partitioning stuff, are not exposed in the Python SDK. Finally, I must stress again, that your question is out of scope of support, which is why we cannot provide any further help here.
c4d.utilsNiehgbor
Cheers, Ferdinand
Hi @inevestenko,
yes, that looks like you are doing what I described under the first approach. But what jumps to the eye, is that you do not handle triangles as you always divide by four in polycenterlp = (ptA + ptB + ptC + ptD)/4. And although Cinema does store triangles as quads in the form of repeating the last vertex in a polygon, this will cause a problem for triangles.
When you have a CPolygon representing a triangle as a quad, i.e. A, B, C, C, then (A + B + C) * 1/3 != (A + B + C + C) * 1/4. So, you are probably calculating the wrong center point there. I might be overlooking something here, but that is what I get from a quick glance. But again, your question is out of scope of support, I am unfortunately not in the position to provide algorithmic support or debug your code for you.
CPolygon
Hey @ferdinand Thanks again! I think the question is closed
