a GeDialog docked in C4D's layout receives a call to Command() with ID 92, when user clicks the little x in the window title. I tested this in R21 to S24.
GeDialog
Other ways to close a dialog do not show this behavior (i.e. close button of floating dialog or "Close Manager" from the hamburger menu of a dialog).
Not a big deal at all. I'm just wondering, what may be the reason or if it might be a small bug?
Cheers, Andreas
Hi, Andreas hope you are fine
I can indeed confirm the behavior, for me looks like a mistake, I sent an email to developers. 92 internally for GUI_DIALOG_CLOSE which seems to be ok, but in the public framework, the value is 1002.
Cheers, Maxime.
Thanks for the info, Maxime.
Just get a reply and it seems because the button is created by Cinema 4D itself when docked and this button simply doesn't exist otherwise.
i removed the ids from the sdk. it looks like they are only used internally. there is no use in the sdk for developers.
