I tried to make a script where when generating a material, assign the active object that material but I do not know if it should go the way I am doing it or it is wrong, I also saw in the script history c4d.ID_MATERIALASSIGNMENTS I guess it has something to do with it but I don't understand mi codigo
import c4d from c4d import gui def main(): cubo = doc.GetActiveObject() c4d.CallCommand(13015, 13015) # Nuevo Material mat = doc.GetAciveMaterial() mat[c4d.MATERIAL_PAGE_ASSIGNMENT] = cubo if __name__=='__main__': main()
Hello @JH23,
thank you for reaching out to us. While it is possible to use CallCommand in scripts for the more basic things like creating a material, it is recommended to use the more abstract object-oriented API whenever possible. Below you will find an example script which creates, modifies and assigns a new material to the currently active object.
CallCommand
Cheers, Ferdinand
"""Example for creating a material and assigning it to the currently active object. As discussed in: https://plugincafe.maxon.net/topic/13357 """ import c4d def main(): """ """ # op and doc a are module attributes predefined by Cinema 4D for a script # module. doc is the currently active document, op the currently active # object in this active document. if op is None: raise RuntimeError("Please select an object.") # Instantiate a standard material and insert it into the document, as # otherwise we could not use it. mat = c4d.BaseList2D(c4d.Mmaterial) doc.InsertMaterial(mat) # Example for modifying the material, here setting its diffuse color. mat[c4d.MATERIAL_COLOR_COLOR] = c4d.Vector(1, 0, 0) # Create a texture tag on the selected object, change the projection mode # to uvw and link the newly crated material to it. tag = op.MakeTag(c4d.Ttexture) tag[c4d.TEXTURETAG_PROJECTION] = c4d.TEXTURETAG_PROJECTION_UVW tag[c4d.TEXTURETAG_MATERIAL] = mat # Notify Cinema 4D of the changes made. c4d.EventAdd() # Execute main() if __name__=='__main__': main()
Hello @ferdinand thank you very much solved my doubts Cheers, JH23
without further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
