On 04/07/2003 at 03:47, xxxxxxxx wrote:
User Information: Cinema 4D Version: 7.303 Platform: Language(s) : C.O.F.F.E.E ;
--------- Hi ! I added several EDITNUMBERs in my GeModalDialog. But these fields don't accept any number other than 0. When I enter a greater or smaller number, a strange ErrorMessage appears when i close the dialog. It says "Please enter a number smaller, greater than or equal to zero". Here is the code from my RES-File. The ID value of DUPLI_DUP_DIST_Y_FIELD is 13950.
EDITNUMBER DUPLI_DUP_DIST_Y_FIELD { CENTER_V; CENTER_H; SIZE 70, 0; }
I can't explain this behaviour. I appreciate your help very much...
On 04/07/2003 at 03:54, xxxxxxxx wrote:
you need to initialize the field in your plugincode (in your dialog class InitValues method) with i.e. SetReal() (see coffee docs for this). Best Samir
