I'm writing an XPresso node, deriving its class from GvOperatorData.
GvOperatorData
The node's .res file looks a bit like this:
CONTAINER mynode { NAME mynode; INCLUDE GVbase; GROUP ID_GVPROPERTIES { REAL MYNODE_ATTRIBUTE_1 { }; BOOL MYNODE_ATTRIBUTE_2 { } } GROUP ID_GVPORTS { REAL INPORT_X { INPORT; NEEDCONNECTION; STATICPORT; CREATEPORT; } REAL INPORT_SOMEVALUE { INPORT; EDITPORT; UNIT PERCENT; MIN 0.0; STEP 0.1; } REAL OUTPORT_VALUE { OUTPORT; STATICPORT; CREATEPORT; } } }
In the code, in Bool MyNode::Calculate(), I do the following to get the values:
if (!GvCalculateInValuesTable(bn, run, calc, _ports)) return false; BaseContainer* dataPtr = bn->GetOpContainerInstance(); if (!dataPtr) return false; if (port && port->GetMainID() == OUTPORT_VALUE) { // Get a value from a port GvPort* const portInputValue = _ports.in_values[0]->GetPort(); Float inputValue = 0.0; if (portInputValue) { if (!portInputValue->GetFloat(&inputValue, run)) return false; } const Float someFloatValue = dataPtr->GetFloat(MYNODE_ATTRIBUTE_2); const Bool someBoolValue = dataPtr->GetBool(MYNODE_ATTRIBUTE_2); }
Getting the values works fine: When getting the value of a port, I'll get either the value that comes on from a connection in the node network, or I'll get the value from the Attribute Manager, if the port is not connected.
Question However, the entry does not disappear from the Attribute Manager once I connect the port. In the builtin XPresso nodes, ports' attribute entry will vanish from the AM when the port is connected. How can I achieve that?
By the way, full code is here: https://github.com/fwilleke80/Oscillator/blob/master/source/node/gvoscillator.cpp
Thanks in advance & best greetings, Frank
hi @fwilleke80, thanks for providing the code, it helped to see where the problem was You need to call the SUPER at the beginning (and not when returnning). And you don't need to load the description as you did with
if (!description->LoadDescription(ID_OSCILLATORNODE)) return false;
This code should work.
virtual Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags) { if (!SUPER::GetDDescription(node, description, flags)) return false; flags& DESCFLAGS_DESC::LOADED; return true; }
Cheers, Manuel
Hi Manuel,
oh right, that does the trick! Thank you, one bug less!
Cheers, Frank
