On 03/07/2003 at 16:15, xxxxxxxx wrote:
I have an idea for a timeline plugin.
Basically I am tired of having to go into the timeline and mess with the settings for interpolation.
I would think it would be great if you could run a plugin that would read a keyframes position and see if the next keyframe in the sequence had the same position. It would then on the event of having the same position then set the interpolation to linear.
What this would do is help out with character animation. Your feet would not bobble around once you planted them on the floor or iany object that you wanted to fix to the floor or table or whatever.
Just a thought
DM
