I got a setup with a stationary camera. i need to keep the object centered in my view and maximize its size but i can't change the rotation / position of my camera.
what i have so far is the following:
i calculate the center of the objekt and change the offset accordingly to center the object. now if i want to zoom in my offset calculations are wrong again.
fovProblem.c4d
edit:
can someone please move the thread into the right subforum?
hi,
Did you had a look at this thread the problem was almost the same (but to create render).
@ferdinand also answer to this question on Core 4D (that was a bit harder to find)
Let us know if those resource helped you or not.
Cheers, Manuel
Hello @pyr,
without any further questions or replies, we will consider this topic as solved by Monday and flag it accordingly.
