Solved ReadFileToMemory() in R20 crashes
I know, R20 is a while old, but maybe someone has an idea...
The following code crashes reproducibly on R20 (definitely on macOS, not yet sure about Windows):
maxon::Url theServer("https://www.myserver.org/somefolder/somefile.json"_s);
maxon::BaseArray<Char> memReq;
iferr (maxon::FileUtilities::ReadFileToMemory(theServer, memReq))
	DiagnosticOutput("@", err);
The same (well, almost the same) code works flawlessly in R21 - R23:
// Set post properties (apparently not yet possible in R20)
theServer.Set(maxon::URLFLAGS::HTTP_POSTMETHOD, method) iferr_return;
theServer.Set(maxon::URLFLAGS::HTTP_POSTDATA, maxon::CString(postData, maxon::StringEncodings::Utf8())) iferr_return;
maxon::BaseArray<maxon::Char> memReq;
Thanks in advance for advice!
Frank
www.frankwilleke.de
Only asking personal code questions here.
I did tried with R20 and it worked as expected. I'm reading a .txt file from a https link. (i did only tried on windows)
Could you send us an email with the link you are using ? (just to be sure I'm testing the same thing)
Manuel
MAXON Registered Developer
Hi Manuel,
thanks for your reply!
Sure, what was the eMail again?
Frank
www.frankwilleke.de
sorry,
sdk_support(at)maxon(dot)net
Manuel
Hi Manuel,
oh, of course. Thanks for the offer!
Will send you a mail this week. Bit busy these days.
Frank
www.frankwilleke.de
Any news on that one ?
Manuel
Hi Manuel,
sorry, I totally forgot about this one. Priorities have changed, so this isn't an issue anymore at the moment.
Thanks!
Frank
www.frankwilleke.de
