hello, I am using the melange sdk to export to c4d files. it looks like DOCUMENT_CLIPPING_PRESET parameter could not be set :
test:
c4dDoc = cineware::BaseDocument::Alloc(); { cineware::GeData udata; cineware::Bool ret = c4dDoc->SetParameter(cineware::DOCUMENT_CLIPPING_PRESET, cineware::DOCUMENT_CLIPPING_PRESET_HUGE); ret = c4dDoc->GetParameter(cineware::DescLevel(cineware::DOCUMENT_CLIPPING_PRESET), udata); }
udata correspond to a value of 1 ( MEDIUM, the default value) I tried with other preset, same issue.
thanks in advance
hi,
the preset will not be changed but the value for near and far clip are updated. I will talked with the dev to see why the preset isn't set. You can use the near and far values as a workaround.
char valuein; auto PrintValue = [](BaseDocument* doc) { cineware::GeData udata; doc->GetParameter(cineware::DescLevel(cineware::DOCUMENT_CLIPPING_PRESET_NEAR), udata); Float n = udata.GetFloat(); doc->GetParameter(cineware::DescLevel(cineware::DOCUMENT_CLIPPING_PRESET_FAR), udata); Float f = udata.GetFloat(); printf("value are near : %f far %f \n\r", n, f); }; BaseDocument* c4dDoc = cineware::BaseDocument::Alloc(); if (c4dDoc != nullptr) { PrintValue(c4dDoc); cineware::Bool ret = c4dDoc->SetParameter(cineware::DOCUMENT_CLIPPING_PRESET, cineware::DOCUMENT_CLIPPING_PRESET_HUGE); PrintValue(c4dDoc); scanf("%c", &valuein); }
Cheers, Manuel
right but when I load my document inside C4d ( R20 or R22), the clipping preset is medium and the clipping near and far are wrong ( back to medium)
