Hello! I have a situation where I'm adding a Random Effector to scene on a button press. That's working correctly, but when I save the scene and reopen it the Field interface and it seems to have reverted to the pre-R20 interface. I'm working in C++ but I managed to recreate the issue in Python for simplicity.
Before I save and load the Falloff tab looks like this.
After I save and load it looks like this.
The code I'm using is here:
import c4d from c4d import gui def main(): randomEffector = c4d.BaseObject(1018643)#Random Effector ID doc.InsertObject(randomEffector) c4d.EventAdd() if __name__=='__main__': main()
Is there a flag or something I'm missing?
Thanks for any help, Dan
hi
you have to send the following message to the object so it will switch internally from regular falloff to fields.
randomEffector.Message(c4d.MSG_MENUPREPARE, doc)
Cheers, Manuel
@m_magalhaes
Thank you! Works perfectly.
Dan
