Hi I have stumbled on a strange problem while calling the object GetDirty(DIRTYFLAGS_MATRIX). The return value is always updated when I toggle the object visibility in either the VP or in render from the object manager. My problem is that I'm currently checking whether the children of my generator have changed and when they do, I tell the generator to recalculate it's output but because GetDirty(DIRTYFLAGS_MATRIX) is updated every time a child visibility is toggled the generator does an unnecessary update that I would like to avoid. I'm using R19 SDK.
hi,
could you be more verbose about the kind of object you are using ? For example mograph's object are really special, almost always dirty. Please also, take a loog at our guidelines to use the forum's functionalities (specially the tags) I'm pretty sure you are talking about python, that information is useful.
Also, sharing some code (if you can) will help us to reproduce the issue.
Are you using a python generator or you are creating your own plugin and your own NodeData ?
NodeData
Cheers, Manuel
Thanks for the reply. I'm talking about a c++ generator but it also happens in Python. There is really no need to share any code, Just print the GetDirty(DIRTYFLAGS_MATRIX) using python after you toggle the object visibility in the object manager and watch it produce a different number every time.
SetDirty(DIRTYFLAGS::MATRIX); is called when you change the editor or render mode. I need to ask our tech team if somebody remember the reason for that.
Hi, Thanks. Waiting for your reply.
Hi Manuel, Any updates on this?
we are in the week of our summit 2021, answer may take longer :)
there's no really workaround expect tracking all the child object's state for the viewport/render mode and check by yourself if those have changes. Depending on what you want to do it could even be worst than rebuilding your cache.
edit : this code have been there for more than 14 years.
