Follow the steps to build, but it fails. How can this be solved?
build it in this step.
Download Project Tool for R23 and place it under C drive C:\projecttool
After installing R23, extract sdk.zip under C drive C:\sdk
Run the Project Tool at the command prompt C:\projecttool\kernel_app_64bit.exe g_updateproject = C:\sdk
Open C:\sdk\plugins\project\plugins.sln using VS2019
Run solution build
Build fails
Error C2079 'maxon::ResultBase<RESULT_TYPE>::_value' uses undefined class 'maxon::BlendAnimationRef' math.framework C:\sdk\frameworks\core.framework\source\maxon\utilities\resultbase.h 571 Error LNK1104 cannot open file 'C:\sdk\plugins\project\_obj\math.framework\x64_Debug\math.framework_Debug_64bit.lib' maxonsdk.module C:\sdk\plugins\maxonsdk.module\project\LINK 1
hi,
I think you are using Visual Studio 16.9. It's a know issue and our devs have found a solution. I've written this post about it and how to fix it.
You have two line to modify in the framework, this update will be included in the next release.
Let me know if this doesn't fix the issue.
Cheers, Manuel
Thank you for your advice. The build was successful !!
