How would I go about downloading a (text) file from a webserver? Ideally, this should be done in a separate thread, so the GUI isn’t blocked while waiting for the server response?
I just want to read what’s in the file, it doesn’t need to be stored locally.
I know, using a separate Python plugin it is very easy, but I’d prefer doing it in C++. If it's possible in R20 - R23, even better.
Thanks in advance & greetings, Frank
hi,
you should have a look at this thread from which, we've updated the documentation.
Using the function ReadFileToMemory you can read the stream to an array and you can use ConvertTextToLines. to have a per-line result
ReadFileToMemory is present since R20 but i didn't tried there.
Let me know if it's working, otherwise I will have a look if i find something better.
Cheers, Manuel
Hi Manuel,
thanks, that looks exactly like the thing I need! Was only looking into NetworkHttpHandlerInterface the whole time...
I'll try this out soon and then report back. Will set this thread to solved, as my question was answered
Thanks & greetings, Frank
It's working perfectly, thanks again! So much easier than I thought
Cheers, Frank
by the way, i forgot to talk about the thread thing.
This thread might help And of course our manuals about threading
Cheers Manuel
