Hi all!
When registering a shader plugin, the "RegisterShaderPlugin" function has a string parameter naming the resource file that should be used for the shader. The docs say this:
The name has to be unique, i.e. "Tdisplay" cannot be used for 2 different descriptions
For my rendering plugin, I am trying to dynamically create GUI representations for externally stored shaders (compiled OSL shaders), loading all shaders in a given directory. This means that the number of shaders to be created, and their descriptions, is not known at compile time but only at runtime (loaded when c4d starts). The solution I am looking at for this is to register the same shader plugin multiple times, but with different IDs. By associating the ID with a specific OSL-shader file, I can then build the correct GUI, representing the OSL shader, in the GetDDescription function of the shader. This almost works, except for the fact that as soon as I register more than one shader, I get a warning in the c4d console that the same description file is being used more than once, and the description is not loaded.
Since the entire GUI is build in GetDDescription, I would not really need the description resource file at all. Is there any way that I can register a shader without specifying a resource file? E.g., is there any way to have a purely dynamic description?
I am also looking a using the RegisterDescription() function to load the resource file once and then using LoadDescription(id) in GetDDescription to load it. So far, I have not had any luck with this approach.
Any other suggestions?
Thanks!
/Filip
