Hi @dskeith,
thank you for reaching out to us. There is unfortunately no solution out of the box with which you can achieve this. And it is also rather unlikely that we will add such a functionality. To implement it yourself, you could make use of either:
c4d.utils.SendModelingCommand
with MCOMMAND_SELECTCONNECTED
. This will work with Ngons, but will come with a lot of overhead due to SMC.
c4d.utils.Neighbor
. You can also make this work for Ngons, but it will bee harder because you have to deal then with the translation maps. Algorithmically this will be "cleaner".
You will find below an example for the first option.
edit: For uvs things would work in a similar fashion.
"""On how to select polygon islands.
As discussed in:
https://plugincafe.maxon.net/topic/13194
Written for R23.
def GetPolygonIslandSelections(node):
"""Yields connected polygon island id lists for a polygon mesh.
Args:
node (c4d.PolygonObject): Description
Yields:
list[int]: An island of polygon ids.
if not isinstance(node, c4d.PolygonObject):
raise TypeError(f"Expected PolygonObject for node, received: {node}")
# The polygon selection of the node and some stuff.
selection = node.GetPolygonS()
count = node.GetPolygonCount()
polygonIdSeeds = list(range(count))
def selectConnected(node, index):
"""Selects the connected polygons for a given polygon index.
selection.DeselectAll()
selection.Select(index)
kwargs = {"command": c4d.MCOMMAND_SELECTCONNECTED,
"list": [node],
"mode": c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
"bc": c4d.BaseContainer(),
"doc": doc}
return c4d.utils.SendModelingCommand(**kwargs)
# We could also write "while polygonIdSeeds:", but while loops give me
# anxiety ^^
for _ in range(count):
# Select all polygons connected to the first polygon id in our seeds.
if not selectConnected(node, polygonIdSeeds[0]):
raise RuntimeError("Something went wrong.")
# Evaluate the new selection state.
island = [i for i, v in enumerate(selection.GetAll(count)) if v]
# Yield the island.
yield island
# Intersect our remaining seed ids with that island.
polygonIdSeeds = [pid for pid in polygonIdSeeds
if pid not in island]
# Break out if we exhausted all of them.
if not polygonIdSeeds:
break
# Clean up the selection.
def CreatePolygonSelectionTag(node, selectionIds):
"""Generates a polygon selection tag for the given polygon ids.
# The polygon selection.
for index in selectionIds:
# Create a selection tag fur the current polygon selection.
kwargs = {"command": c4d.MCOMMAND_GENERATESELECTION,
"list": [node],
"doc": doc}
"""Entry point.
i = 0
for island in GetPolygonIslandSelections(op):
if not CreatePolygonSelectionTag(op, island):
raise RuntimeError("Could not create polygon selection tag.")
i += 1
print (f"Added {i} selection tags.")
