NodeData: How to get connected GeListNode
Hello.
I'm currently searching for a way to retrieve the GeListNode instance from within a custom method of a NodeData plugin. Similar to C++ Get()Inherited functions come with a
node
parameter, but there doesn't seem to be a way to retrieve the connected ListNode in custom functions?Am I overseeing something?
Hi @mp5gosu.
There is no such Get method in python, however normally all methods to override in a NodeData and derived classes should expose the current BaseList2D instance, so you just need to forward it.
Maybe a method is missing this BaseList2D instance if yes could you point it to us?Cheers,
Thought so.
No, there's nothing missing in inherited methods. Thought, it'd be convenient. However, storing it to a member variable on init or forwarding does the trick.
