Hi there!
I am trying to recompile an older Plugin to R21 and am having trouble getting it to build correctly.
My C++ and VisualStudio knowledge is very limited so I might just be making some basic mistakes.
I got the R21 sdk and replaced the demo plugins with the old R20 one.
I am using VS2019, but I switched the Platform Toolkit for the plugin and the frameworks to 2017. (Using VS2019 works fine to compile the R20 plugin with the 2015 toolkit)
When building I get a bunch of syntax errors for the frameworks like:
Error (active) E0757 member "maxon::ClassInterface::REF" is not a type name
And I get this error for several places where a global array is modified like myBaseArray.Append(plugin_id);
C4834 discarding return value of function with 'nodiscard' attribute
I have searched around for a while but I don't know how to fix this. Do I have to modify the code, or is this an issue stemming from an incorrect setup of the VisualStudio project?
