hi,
this doesn't seem to be the right way to do it. If the fields object isn't a child of your effector, this will not work.
Our DropEffector example wasn't working with fields (only falloff) so I've updated it.
I'm not sure where you are adding your code so i'm not sure why it's not working.
Here's the updated version of the drop effector. Could you try to compile it on your side and tell me if it's working or not. If not, how to reproduce the issue
// this example demonstrates how to implement a more complex direct control effector
// and utilize falloff and strength directly
// the effector drops the particles to a surface
#include "c4d.h"
#include "c4d_symbols.h"
#include "lib_collider.h"
#include "c4d_baseeffectorplugin.h"
#include "c4d_falloffplugin.h"
#include "oedrop.h"
#include "main.h"
struct DropEffectorData
BaseObject* target;
Int32 mode;
Float maxdist;
Matrix genmg, igenmg;
Matrix targmg, itargmg;
class DropEffector : public EffectorData
public:
DropEffectorData ed;
AutoAlloc<GeRayCollider> rcol;
GeRayColResult rcolres;
virtual Bool InitEffector(GeListNode* node);
virtual void InitPoints(BaseObject* op, BaseObject* gen, BaseDocument* doc, EffectorDataStruct* data, MoData* md, BaseThread* thread);
virtual void ModifyPoints(BaseObject* op, BaseObject* gen, BaseDocument* doc, EffectorDataStruct* data, MoData* md, BaseThread* thread);
static NodeData* Alloc() { return NewObjClear(DropEffector); }
Bool DropEffector::InitEffector(GeListNode* node)
if (!rcol || !node)
return false;
BaseObject* op = (BaseObject*)node;
if (!op)
return false;
BaseContainer* bc = op->GetDataInstance();
if (!bc)
return false;
bc->SetFloat(DROPEFFECTOR_DISTANCE, 1000.0);
return true;
void DropEffector::InitPoints(BaseObject* op, BaseObject* gen, BaseDocument* doc, EffectorDataStruct* data, MoData* md, BaseThread* thread)
if (!bc)
return;
if (!rcol)
return;
ed.mode = bc->GetInt32(DROPEFFECTOR_MODE);
ed.maxdist = bc->GetFloat(DROPEFFECTOR_DISTANCE);
ed.target = bc->GetObjectLink(DROPEFFECTOR_TARGET, doc);
if (!ed.target)
return;
ed.targmg = ed.target->GetMg();
ed.itargmg = ~ed.targmg;
ed.genmg = gen->GetMg();
ed.igenmg = ~ed.genmg;
// Add a dependency so that the effector will update if the target changes
AddEffectorDependence(ed.target);
// Can't init raycollider or the target isn't polygonal, then skip
if (!rcol->Init(ed.target))
ed.target = nullptr;
else if (!ed.target->IsInstanceOf(Opolygon))
void DropEffector::ModifyPoints(BaseObject* op, BaseObject* gen, BaseDocument* doc, EffectorDataStruct* data, MoData* md, BaseThread* thread)
if (!ed.target || !rcol || data->strength == 0.0)
return;
C4D_Falloff* falloff = GetFalloff();
FieldOutput* fieldSample = nullptr;
if (!falloff)
fieldSample = CalcFields(doc, gen, md, FIELDSAMPLE_FLAG::VALUE);
if (!fieldSample)
return;
Int32 i = 0;
Float fall = 0.0;
Vector off = Vector(0.0);
Vector ray_p = Vector(0.0), ray_dir = Vector(0.0);
Vector targ_off = Vector(0.0), targ_hpb = Vector(0.0);
MDArray<Int32> flag_array = md->GetLongArray(MODATA_FLAGS);
MDArray<Matrix> mat_array = md->GetMatrixArray(MODATA_MATRIX);
MDArray<Float> weight_array = md->GetRealArray(MODATA_WEIGHT);
if (!mat_array)
return;
Int32 mdcount = (Int32)md->GetCount();
for (i = 0; i < mdcount; i++)
// If the particle isn't visible, don't calculate
if (!(flag_array[i] & MOGENFLAG_CLONE_ON) || (flag_array[i] & MOGENFLAG_DISABLE))
continue;
// Multiply into global space
off = mat_array[i].off;
off = ed.genmg * off;
// Sample the falloff
if (falloff)
falloff->Sample(off, &fall, true, weight_array[i]);
else
fall = fieldSample->_value[i];
if (fall == 0.0)
continue;
// Set up the ray for the collision
ray_p = ed.itargmg * off;
switch (ed.mode)
default:
case DROPEFFECTOR_MODE_PNORMAL: ray_dir = ed.genmg.sqmat * mat_array[i].sqmat.v3; break;
case DROPEFFECTOR_MODE_NNORMAL: ray_dir = -(ed.genmg.sqmat * mat_array[i].sqmat.v3); break;
case DROPEFFECTOR_MODE_AXIS: ray_dir = (ed.targmg.off - off); break;
case DROPEFFECTOR_MODE_SELFAXIS: ray_dir = (ed.genmg.off - off); break;
case DROPEFFECTOR_MODE_PX: ray_dir = Vector(1.0, 0.0, 0.0); break;
case DROPEFFECTOR_MODE_PY: ray_dir = Vector(0.0, 1.0, 0.0); break;
case DROPEFFECTOR_MODE_PZ: ray_dir = Vector(0.0, 0.0, 1.0); break;
case DROPEFFECTOR_MODE_NX: ray_dir = Vector(-1.0, 0.0, 0.0); break;
case DROPEFFECTOR_MODE_NY: ray_dir = Vector(0.0, -1.0, 0.0); break;
case DROPEFFECTOR_MODE_NZ: ray_dir = Vector(0.0, 0.0, -1.0); break;
ray_dir = ed.itargmg.sqmat * ray_dir;
// Calculate an intersection
if (rcol->Intersect(ray_p, !ray_dir, ed.maxdist, false))
if (rcol->GetNearestIntersection(&rcolres))
fall *= data->strength;
targ_off = Blend(mat_array[i].off, ed.igenmg * (ed.targmg * rcolres.hitpos), fall);
targ_hpb = VectorToHPB(ed.igenmg.sqmat * (ed.targmg.sqmat * rcolres.s_normal));
mat_array[i] = HPBToMatrix(Blend(MatrixToHPB(mat_array[i], ROTATIONORDER::DEFAULT), targ_hpb, fall), ROTATIONORDER::DEFAULT);
mat_array[i].off = targ_off;
// be sure to use a unique ID obtained from www.plugincafe.com
#define ID_DROPEFFECTOR 1019571
Bool RegisterDropEffector()
return RegisterEffectorPlugin(ID_DROPEFFECTOR, GeLoadString(IDS_DROPEFFECTOR), OBJECT_CALL_ADDEXECUTION, DropEffector::Alloc, "oedrop"_s, AutoBitmap("dropeffector.tif"_s), 0);
Manuel
