GetClone creates a take from a source take but its overrides are linked to source take. if I remove overrides from cloned take, original take's overrides also deleted. Is this a bug or GetClone produces a kind of instance object with linking to source object? How can I fix this? How can I break them from the source take?
- open attached c4d doc
- select Sphere take
- run this script
- script will clone sphare take under main take. Newly cloned take have 2 overrides: 1) for X location and 2) for layer properties.
- activate newly cloned Sphere take
- activate AutoTake and Lock Override buttons
- change Sphere's X location and/or sphare layer visibility values
- you will see that c4d will add another override lines under already existent overrides
# Script clones selected take to under Main Take
# AliasTrans did not work
#trans = c4d.AliasTrans()
#if trans is None or trans.Init(doc) is False:
# return False
#clonedTake=selectedTake[0].GetClone(c4d.COPYFLAGS_0)
#trans.Translate(False)
takeData = doc.GetTakeData()
mainTake=takeData.GetMainTake()
selectedTake=takeData.GetTakeSelection(0)
doc.StartUndo()
doc.AddUndo(c4d.UNDOTYPE_CHANGE, mainTake)
clonedTake.InsertUnder(mainTake)
doc.EndUndo()
#gui.MessageDialog('Hello World!')
# Execute main()
if __name__=='__main__':
