I'm trying to do some things using Python, so I wrote a simple function to execute Python code, based on the example in the SDK docs. I've been using this function before (see https://plugincafe.maxon.net/topic/12973/opening-a-maxon-url-in-the-browser-anchors-and-query-parameters/3) with no problems.
Here is the code to execute Python code from within a C++ plugin:
maxon::Result<void> ExecutePythonCodeSimple(const maxon::String &code) { iferr_scope; // Check code if (code.IsEmpty()) return maxon::IllegalArgumentError(MAXON_SOURCE_LOCATION); // Create VM ref and scope #if API_VERSION >= 23000 const maxon::VirtualMachineRef& vm = MAXON_CPYTHON37VM(); #else const maxon::VirtualMachineRef& vm = MAXON_CPYTHON27VM(); #endif const maxon::VirtualMachineScopeRef scope = vm.CreateScope() iferr_return; // Init script iferr (scope.Init("Python Script"_s, code, maxon::ERRORHANDLING::PRINT, nullptr)) { const String errorMessage = "Error on Init()"_s; return maxon::UnknownError(MAXON_SOURCE_LOCATION, errorMessage); } // set __name__ = __main__ scope.Add("__name__"_s, maxon::Data("__main__"_s)) iferr_return; // executes the script and returns when it got executed. // info: if the script causes an unexpected infinite loop, Execute() does not return // and there is no way to stop from the outside. iferr (scope.Execute()) { const String errorMessage = "Error on Execute()"_s; return maxon::UnknownError(MAXON_SOURCE_LOCATION, errorMessage); } return maxon::OK; }
The Python code I want to execute relies on functionality from the c4d package. Here's the - very simplified - code:
c4d
maxon::Result<void> MyFunction() { iferr_scope; maxon::String theCode; theCode = "import c4d\n"_s; theCode += "print('Hello World!')\n"_s; // Execute code ExecutePythonCodeSimple(theCode) iferr_return; return maxon::OK; }
So, the actual Python code comes down to this:
import c4d print('Hello World!')
It crashes reproducibly:
If I remove the line import c4d, it does not crash.
Why, and how can I solve this?
Thanks in advance & best greetings, Frank
You are calling the Python module before it is loaded and initiated. You could try setting the priority of your plugin to ensure it is the last plugin loaded.
Also you shouldn’t be calling that in PluginStart. You should be calling it once all the plugins have been started, ie the Python module.
Instead try calling it on StartActivity or possibly Program_Started.
https://developers.maxon.net/docs/Cinema4DCPPSDK/html/page_manual_module_functions.html#page_manual_module_functions_functions_message_start
Hi Kent,
thanks! I'll try that! I was under the impression, that all "built-in" modules are registered before the plugins. Will reply here and report if that solved it
Cheers, Frank
I was in deed calling the code from within PluginStart(). Calling it from PluginMessage(C4DPL_STARTACTIVITY) fixed it. Thank you, Kent!
PluginStart()
