BitmapButtonCustomGui hover
Hi folks,
is there a flag to prevent the change in background colour when you hover over a BitmapButtonCustomGui with a transparent image on it? I want just a static image that does nothing when you mouse over. I'm currently using a GeUserArea, which works fine, but seems a little cumbersome to make just for a static image.
Or is the user area the only way?
WP.
Hi @WickedP,
thank you for reaching out to us. And the answer to your question is: Yes, this is possible with a
. However, this feature is only available with S22 onwards (please remember to add version tags to your posting in the future). The relevant flags are documented here for C++ and here for Python (I am aware that you are on C++, but the Python docs are a bit nicer in this case). The settings flag you can use for this with S22+ isBITMAPBUTTON_DISABLE_FADING
. I have added the little Python script with which I did test the flag at the end. When you need a specific C++ version or any further help, please do not hesitate to ask.Cheers,
Ferdinandimport c4d class PC13071Dialog(c4d.gui.GeDialog): """Dialog demonstrating a CUSTOMGUI_BITMAPBUTTON with a static background color. """ ID_BITMAP_BUTTON = 10000 # The gadget ID for the button. def CreateLayout(self): """Creates the layout for the dialog. """ # The settings for the CUSTOMGUI_BITMAPBUTTON bc = c4d.BaseContainer() # Its a bitmap button. bc[c4d.BITMAPBUTTON_BUTTON] = True # The first icon (and only icon for a non-toggle button). bc[c4d.BITMAPBUTTON_ICONID1] = c4d.OBJECT_FIGURE # The default background color. bc[c4d.BITMAPBUTTON_BACKCOLOR] = c4d.COLOR_BG # Disable the mouse over fading. This feature is only available in # S22 onwards (which the C++ docs do not currently point out # correctly). bc[c4d.BITMAPBUTTON_DISABLE_FADING] = False # Add the gadget. self.bitmapButton = self.AddCustomGui(PC13071Dialog.ID_BITMAP_BUTTON, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER | c4d.BFV_CENTER, 0, 0, bc) return True def main(): """Entry point. """ # Little nasty hack to expose the dialog object to the module and make # async dialogs work (which is required for the bitmap button). Please # do not do this an production environment. This is only for the purpose # of quickly demonstrating the CUSTOMGUI_BITMAPBUTTON. global dialog # Open our dialog. dialog = PC13071Dialog() dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=-2, defaulth=-2) if __name__ == '__main__': main()
Thanks Ferdinand,
sounds like it won't be available for me (I'm pre-s22). I can live with the GeUserArea, but good to know it's available for more recent releases.
Two other things. Firstly, congrats on becoming a Maxon support member!
Secondly, I can't seem to mark any topics of mine as solved. Has this changed?
WP.
Hi @WickedP,
that is because you haven't set your topic as "ask-as-question" in the first place ;) So there is nothing to resolve here.
