Hello!
I was trying to create a LipSync Engine built using Python and the Sound Effectors included in the MoGraph package.
For some reason, I saw some mismatch in Sound Effector Build between R14, the one made in R18, and the one in R19.
This is the screenshot of the Effector Tab in the versions I got (R14, R18, and R19)
Hi @SolarPH,
thank you for reaching out to us. First of all I would like to point out that the support cycle of Cinema 4D is two major versions. We however take it as a compliment that you consider Cinema 4D being so stable to having such long lasting backwards compatibility But there were of course some changes over the course of the years which did break some compatibilities, including the sound effector.
Regarding your last question:
If we base on the sound effector, and the waveform on the timeline, the offset does not work apparently, or am I missing something?
As this clearly falls into the domain of the end-user support, I would have to ask you to contact them about it.
Actually nevermind. I found a workaround for this
However... If we base on the sound effector, and the waveform on the timeline, the offset does not work apparently, or am I missing something?
without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
Cheers, Ferdinand
