How to catch Preferences editing
Hello folks!
I need that my main Command plugin dialog react on some edits in Cinema 4D Preferences.
How it possible to track? Watching with Timer or maybe there is some CoreMessage() trick?
thank you!
Hi @mikeudin,
looking at the implementation of the node that is internally attached to the preferences dialog, I have to confirm what the public documentation implicitly states - that there is no message being broadcasted. The next best solution would be probably to cache the preferences yourself and then regularly compare that cache against the live settings via
GetWorldContainerInstance
and aMessageData
with a timer for example.This of course will come with considerable overhead, but I do not see any other solution right now.
edit: Instead of using a timer, you could also listen for
EVMSG_CHANGE
in your dialogsCoreMessage
, slightly reducing the overhead. This will work because the preferences are a represented as a node and edits will then be reflected by such core message.Cheers,
Hi @mikeudin,
and aMessageData
EVMSG_CHANGE
without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
