Hi, I have a null object that has 3 user data variable on it. My take structure is like below. Every branch null object's data values are changed as mentioned below:
but, for example after data values are changed (while auto take and lock overrides are active) parent values are changing (Step1 and Main)
My explanation may be confusing so you can find the scene file below. Please try to
I tried to understand this behavior but I could not understand yet. could anyone know why parent take values are changing after sub take values are changed?
(Cinema 4D Latest version) scene file:UserData_Take_problem.c4d
thank you
hi,
thanks for reaching us out with that strange behavior you are facing. Are you sure the take is active when you change the values ?
While i couldn't reproduce your issue i have to inform you that this forum is reserved for only API issue/discussions.
For other related "bug" please contact our support at this url support.maxon.net/
Cheers, Manuel
without further feedback, we will consider this thread as solved by Monday and flag it accordingly.
Cheers, Ferdinand
