Setting volume as dirty doesn't refresh in S22 or R23.
I have a VolumeObject that is returned as a call to GetVirtualObjects.
Inside GetVirtualObjects I load in a new vdb file from disk and call the following...
_volumeObject->SetVolume(volume);
_volumeObject->SetDirty(DIRTYFLAGS::ALL);
This work for R20 and R21. But not in S22 or R23.
Any ideas what might be wrong? Is there some other flag I need to set to make the viewport detect a change to the VolumeObject and make it update?
How does the VolumeLoader update the viewport when it loads in a new VDB? I will need to do the same thing for my Object.
What flags does the VolumeLoader set when it is registered? Perhaps I need to add a new flag?
Thanks,
Kent
Hi @kbar I'm able to reproduce the issue and I've opened a new bug report about it.
The only workaround is to return a new VolumeObject each time.Cheers,
