On 13/06/2003 at 13:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Windows ; Language(s) : C++ ;
---------Well, see topic. FlushUnusedTextures() doesn´t work at all...
On 14/06/2003 at 01:04, xxxxxxxx wrote:
As far as I can tell it works perfectly as long as all textures are used... But more seriously, are you sure you're not confusing this function with Remove Unused Materials? See BaseChannel::FreeTexture() for more information. (I don't think it's possible to verify that the function works, unless you perhaps look at how much memory C4D uses before and after.)
On 14/06/2003 at 02:53, xxxxxxxx wrote:
Quote: Originally posted by Mikael Sterner on 14 June 2003 > > * * * > > As far as I can tell it works perfectly as long as all textures are used... > > * * * ROFL :)) > Quote: Originally posted by Mikael Sterner on 14 June 2003 > > * * * > > But more seriously, are you sure you're not confusing this function with Remove Unused Materials? See BaseChannel::FreeTexture() for more information. (I don't think it's possible to verify that the function works, unless you perhaps look at how much memory C4D uses before and after.) > > * * * > > Upps, yes I really thought that this is it. Ok, my fault. (why isn´t there the Remove Unused Materials in the SDK? Or is there?) > > Thank you!
